![]() | Home > Maintenance & Mods (L322) > annoying fan squeal when opening door. SOLVED |
If you remove the horizontal panel above the foot pedals you will find an electronic sounder that gives out the "boings". I would try unplugging the sounder to eliminate it as the cause of the sound you hear. |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Check the e-box fan, located in the depths of the e-box on the LHS of the engine compartment. It keeps all the electronics cool during high temperatures.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
well, after advice from this posting, i heard the fan squeal again, and thinking it WASNS'T the under bonnet brain box, i hunted and hunted for that noise. eventually i opened the bonnet, and thumped the ecu brain-box, and hey presto, it stopped! later that week, i read up on changing it out. but seeing that it costs around £200 i thought i would try something DIY. i got it out and all it is, is a small 12v motor, a quitesmall squirrel cage fan, and a small printed circuit board. -around £20 worth at that. i removed the guts, and after prising off the cage fan, and pulling motor, i felt that it seemed not to spin, (in my fingers, -but it turned, like it was running dry so i wd40 the bearings, lightly, and immediately it seemed to spin, (in my fingers) so, i put in a small drop each end of 3in1 oil. i spun it a few times, and it semed better. reasembeled and it seems to be fine now. it used to squeal every few days, and its been good now for a week, but i will report back if still happens.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Good tip and fix |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
Now.......
when my car made the noise, it would do it as i opened the door, and i would hear nothing for about 1-2 seconds then the squeal, so it wasnt doing it while 'asleep' at least i assume so. -also, whilst this has been going on, i have not had any battery isues. though i did whack in a new bosch 5 year supersize, after about one month of ownership, as i have come from p38 ownership, and this seems the only way to know you have a proper battery to start with.
