Home > Maintenance & Mods (L322) > Diff oil leak + open hose near oil filter
Patricktet
2006 Range Rover Vogue Td6 Buckingham Blue
Hi,
Just noticed that the left side of the front diff is sprayed with oil and road grime. I didnt have the right allen key (14mm?) to open the fill plug to check the level but when looking up I noticed some oil on the oilcooler(?) and an open hose with some oil on it. What is it? Could it have sprayed the left side of the front diff with oil from above?
Finally, should the filter in the last photo look like this?
 MY 06 Vogue TD6 Buckingham Blue
Post #210586 16th Sep 2013 6:03pm
The open hose by the oil filter and the other filter are the same as mine so would suggest these are OK. .
Post #210594 16th Sep 2013 6:45pm
The open pipe next to the filter is the breather for either the front diff or the transfer box (can't remember which but there will be two such pipes in the vicinity) From your description it could be that your diff vent is blocked causing oil to spew out over the housing.
Post #210597 16th Sep 2013 6:53pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
The small filter is the breather for the gearbox .
Post #210674 17th Sep 2013 8:14am
