Home > Maintenance & Mods (L322) > Knocking on near side front |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
ok. ... - .- -.
17th Sep 2013 2:51pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
Car is great no knocking now and a better drive so will get the four wheel tracking looked at now |
17th Sep 2013 9:40pm |
excellant. ... - .- -.
18th Sep 2013 8:42am |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 |
Mine has similar symptoms
19th Sep 2013 8:41pm |
How much was the parts? |
Bush was just over £40 and ball joint £15 |
19th Sep 2013 9:02pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Good job Steve - mine had a similar knocking and a near side ball joint sorted it
19th Sep 2013 9:26pm |
I need to when i bought the car they did th O/S ball joint and arm so now they all are ok it needs it will steer better and also get better tyre life |
20th Sep 2013 9:50am |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 897 |
how easy job is this to do? |
20th Sep 2013 11:30am |
Not hard but need a bit heat on arm to get bush out if you use a vice like me but a press would make the job easier.
20th Sep 2013 12:52pm |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 |
How long do they last? Replaced front arms last year / 18k miles ago and got knocking again?
23rd Sep 2013 10:43pm |
did you do the ball joints |
24th Sep 2013 9:12am |
Did you fit genuine LR parts from Land Rover or were they 'OE' from another source? |
24th Sep 2013 9:16am |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
had the same prob on mine replaced the ball joints ,replaced the upper bushes ,still knocking,i finally found it to be the nearside track rod end ,did that tracked it up perfect,different car to drive now. |
25th Sep 2013 10:04am |
