![]() | Home > Technical (L322) > Misfire help. |
Simusmaximus Member Since: 06 Mar 2013 Location: South Wales Posts: 60 ![]() ![]() ![]() |
Hi vnitos,
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
Fuel was at 3/4 level when misfire happened - I try never to run the car below 1/4 tank.
Relief about misfire being gone was shortlived. Used the car today for the first time since I last posted (wife used it) and found that it still does the same, especially at idle and when cold.
Looking at the to do list, that sounds like a sensible approach. You may consider replacing the MAF sensor iso of just cleaning but after you did all the other stuff.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
On way home from Pub tonight, about midnight (one pint only) car running fine. Traveling on meandering country lane, on the flat, when power suddenly lost and engine stops when put into neutral after coasting to a stop. Engine restarts OK but with the engine warning light on. Travel a few hundred meters and stops again. After a few stop/starts I come to a hill with a fairly steep gradient and it finally gives up the ghost completely. Get my good wife to come out a mile or two, in her car, with a can of petrol (lawnmower usage). About 3 or 4 liters put into tank and after a couple of attempts the motor fired up hesitantly and made it home OK. By the time we got home the engine was running sweetly. At the time the fuel remaining range was indicating just below 60 miles with the fuel warning light coming on during attempts to restart car. I have run the tank down previously to 30 miles remaining with no apparent problem! Checking through the forum I see a lot of folk like to keep their fuel tank levels above a quarter which I have never done with any other car I have run! I take it that the engine warning light (steady amber) will reset itself eventually, or does it need plugging in to a code reader and resetting? Previous cars:
Trawling round other posts looks like it is to do with the shape of the fuel tank and duff fuel transfer (Jet) pump.
some feedback
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
have you looked at the coils? mine had a misfire after washing and had managed to get water into the Coil pack area. removed coils and plugs and tissue paper in the holes and removed all the moisture. when back together it ran like new. Do you have any diagnostics? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Have you tried QUALITY injector/system cleaner? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
Diesel injector cleaner in petrol cars, Gaz ? (only curious - is this an option for the petrolheads as it is better than using a petrol injector cleaner?) .
Sorry should HAVE READ the whole thread |
Feedback time
