Home > Maintenance & Mods (L322) > led halo's
Page 5 of 6 <123456>
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Great job Dave, well done!
Post #156306 9th Dec 2012 6:07pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Daveo would these work on a 2003? As I love the look of these. Bushy
2003 RR Vogue Monté Carlo Blue
Post #187931 12th May 2013 7:16pm
daveo
yes they would, i gave some advice to a chap who has done his square head lights, the glass on your head lights come off far easier then the later ones, you just need to measure to find out size rings you need, he never came back to me with the sizes he used.. V8 facelift Range Rover Autobiography 22" wheels.
Post #187933 12th May 2013 7:44pm
Bushy513
Thanks for the quick reply Daveo, I don't suppose you still remember where you got the loom from the one with the split for courtesy lights. I personally think that feature would be awesome.
Such a cool mod for less than £100.
Is this all I would need?
2x big rings
2x smaller rings
Loom
2x resistors Bushy
Post #187937 12th May 2013 7:59pm
pld118
Do Professionals do this?
Hi,
Does anyone please know if professionals will do this upgrade as opposed to DIY. It appeals but I would lack the confidence to do this myself?
Thanks
Post #211041 19th Sep 2013 10:11am
Googsy
Camtech Craig site sponsor can do these blindfolded standing on one leg in stilettos with an arm tied behind his back in the dark! PM him Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #211042 19th Sep 2013 10:15am
ebajema
@ Googsy, you have quite a way with words.
I was a bit apprehensive about opening the headlights, I only had a hair-dryer available and that worked fine. I had it on full heat and full blast, kept heating it all around and evenly and it came off as described by other, putting pressure to "peel of" the "glass" while keeping the heat going. After that it was a doddle.
Mind you the rings are not working but that is probably a wiring fault (the plus and minus are inverted) or all four rings are broken or no power to the wiring (I put them in parallel to the side lights). I plan to look into that later. MY 2010 5.0 SC Galway green and sand interior!!
Post #211043 19th Sep 2013 10:24am
i've ordered a pair of neon type rings from china to put on top of my fog lights..i should be able to somehow silicon the things onto the light and with the outer trim pressing down on it it should be secure [in theory]
Post #211050 19th Sep 2013 10:59am
Googsy
You should test the rings first before fitting I used a battery from a cordless drill. One thing to note the wiring is not logical. There are two wires for the existing sidelights these are black and red. when connecting the halos its not black to black and red to red. Its actually black to red and red to black. hope that helps. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #211059 19th Sep 2013 11:37am
i always test before fitting Conner but thanks for the info mate.. Thumbs Up ... - .- -.
Post #211065 19th Sep 2013 12:01pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Anyone know where I can get my lights converted? I have a spare set of Bi-Xenons which are adaptive and were in the RR when I bought it. I got a set with LED's but these are not adaptive so would like to have the originals converted.
Happy to pay for the cost of parts, return shipping and a reasonable charge got labour if someone can convert for me, ideally I would use as DRLs but could live with them
On the sidelight circuit. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #235923 19th Jan 2014 7:05pm
JAYBOY
Rej
This ones are for your car.
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...1e859190ee
It maybe worth contacting him and ask if he does the conversion.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #235927 19th Jan 2014 7:28pm
these do conversions,
http://www.meduza.co.uk/lighting/
Post #235929 19th Jan 2014 7:43pm
pld118
Quote Rej "This ones are for your car."
I got quoted £325 for the above conversion if I supplied my own lights and refitted them myself which will require some minor electrical work at the point of refitting, hence they are not straightforward 'plug and play' although the company says it's an easy job for a competent DIYer or a pro.
I decided to stick with the stock factory lights, aside to sourcing LED bulbs.
Post #235935 19th Jan 2014 7:57pm
rej
I have the eBay ones but they don't have the. Turning lights. I asked about transferring the bits over from my adaptive lights and was told that it could not be done. When I ordered I was unaware that there were different types for the same shape but ordered as the originals were misted up and one part (now know to be turning light) was slightly distorted. Did think of trying to swap the bits with LEDs from the new lights which I fitted to the old lights but may then end up having to buy a third set if I can't put back together so would rather just try to work on the originals (I can live with the melted bit).
I have seen on here how to take apart but not how to reassemble to stop them leaking etc. Do the halos require a ballast as some I have seen do as do the ones I have on my BMW. There is a difference between knowing your sh!t and knowing you're sh!t
Post #235957 19th Jan 2014 9:44pm
