Home > Technical (L322) > IID TOOL & Clearing 'Inspection' Message
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Purchased the car last Nov, did an oil change around march and used IIDTool to reset the service counter (wasn't displaying a message tho - just wanted to do an oil change for peace of mind)
Other day the 'Inspection' message started popping up on startup and the date 10/2013
reset the counter with IIDTool and its still comming up but now shows 10/2014
Any way to stop it showing on startup?
Thanks.
Post #211107 19th Sep 2013 4:14pm
wealy
Which iid tool did you use?
Post #211110 19th Sep 2013 4:28pm
Katash
Standard one back when I first did it then I used the IIDTool BT few days ago.
Post #211120 19th Sep 2013 4:59pm
Katash
Bump
Post #214338 5th Oct 2013 9:35am
only guessing but have you thought of a battery dis-connection ? ... - .- -.
Post #214345 5th Oct 2013 9:48am
If its anything like BMW, i reckon that The inspection date is written into a non-volatile area of (possibly) several ECUs in the same way that the mileage is, so that disconnecting the battery won't have any effect. Got - 2017 SDV8 Autobiography in Loire Blue
Post #214346 5th Oct 2013 9:52am
Katash
I will give it a go anyway .... Its no major problem, just slightly annoying
Post #214442 5th Oct 2013 1:49pm
Try the manual approach in the wiki (secret codes) .
Post #214469 5th Oct 2013 3:03pm
Katash
yrea tried that - didn't work Sad
Post #214578 5th Oct 2013 10:27pm
try changing the date on the touchscreen to something after 10/14 then reset it again, then change the date back to normal..
now email GAP cos the above didnt work.. Laughing ... - .- -.
Post #214611 6th Oct 2013 10:14am
Katash
Yea tried changing the date but went backwards, the inspection message then showed 10/13.
Post #214628 6th Oct 2013 11:16am
