![]() | Home > My Range Rover > That Magic Number |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
He's been out in mine. I reckon that was enough to hook him..... 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
| Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261
Well done! |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Can I get a well done too - Just clicked over 150,000 miles today. Bought two years and two weeks ago with 85,000 on the clock.
| Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556
Nice one Simes |
It will almost certainly blow up on the way home now I've mentioned it! |
| NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156
Well done Simes! |
| Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291
Wow 150K??? So there is still some life left in mine. Congrats guys |
Previous car (P38 4.6L) I sold at 167,000 miles - was still going strong - and as this BMW engine is supposed to be better than the old Rover V8, I'd expect it to still be going strong at 200,000. |
| CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750
Lucky you! I had a P38 4.6HSE too, very good car, no problems till about 180,000kms when I had to add more water than petrol. It seems they have suffered from porous blocks. The 4.0L seemed to be better as the block was less bored out, my dad is still running a 1998 one without any problems whatsoever. |
A well known problem - not that the block was actually porus - usually it was a cylinder liner either moved or cracked. Something I never experienced despite having 4 3.9's (that were famously effected) and 3 4.6's. All running on LPG - and all at starship mileages.
P38 4.6's were prone to failing engines because the machining from the bores to the water chambers was so thin. Also remember that the engine castings would have been worn as the engine was being phased out, thereby exacerbating any inherent failings in the engine bore size. The 4.0 was stronger as it didn't suffer so much from the wear.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
Just to report reached the 150,000 miles milestone today
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
The 4.0 & 4.6 had exactly the same bore! Different pistons & crank shaft changed the cc's between 4.0 & 4.6... Old wives tail that one was bored out more I'm afraid...! |
