![]() | Home > Technical (L322) > Transmission question/error |
U0155 Lost Communication With Instrument Panel Cluster
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35830 ![]() ![]() |
is your dash panel ok, speedo working etc? ... - .- -.
However if you get "Transmission Overheat - Safe mode" that's a different story altogether.... |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Hi Stan,
Stan it a known RR issue its when there is not enough power in the battery when the key goes in the immobiliser. Not all immobiliser checks complete and the car is limited to third gear. See my fix above. ![]() |
Hi Gaz, Battery seems to be fine though, car used daily. |
You need to clear the fault... |
Unnecessary quote removed
That should be enough. I had the same fault and phoned the Indy we use and fix is as posted above. Never happened again after charging the battery.
Thanks.
If battery is good and fault is cleared & fully reset than all should be OK. |
OP said it happened whilst driving...i asked re the dash as if the speedo is not functioning then the wrong info is sent to the ecu and this limits the gears to 3rd. ... - .- -. Y. O. L. O. . |
