Home > General (L405) > Smoke from the exhaust
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
When accelerating today there was lots of smoke from the exhaust....also, when driving in town it's not really shifting into higher gear, always around 1500rpm, drives my nuts Rolling Eyes
Could you guys enlighten me please Question Normal or should I have it checked...
Thank you guys,
JJ
Post #209386 10th Sep 2013 6:30pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
If it's a V8 then there is a batch of cars that need the turbo scavenge modification that first cropped up on the L322. Suggest a visit/call to dealer to check.
Can't help with gear change question. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #209447 10th Sep 2013 10:46pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
Agree with Nick. Had the same issue 're smoke on hard acceleration and it required visit to dealer and some modification to turbo and oil drain. Known problem so should be able to fix. Get it done sooner rather than later as it affects dpf. Few members on here have had similar issues and haven't seen any recurrence on mine following fix last month. MY11 Vogue 4.4 TDV8 - "African Queen"
Post #209456 10th Sep 2013 11:56pm
Nick Ground
As per Shalz, my L322 suffered DPF failure after the modification as it was one of the first cars to exhibit the drain issue so do not delay. I was surprised when the problem showed up again on the L405 too. But after the very first time it blew smoke there was no delay and it was in for the mod' (VIN number tells them if it is likely to be affected). Proves that the SDV8 is just a chipped TDV8 I guess? 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
Post #209466 11th Sep 2013 7:16am
Java Jungle
Thank you guys, very helpul Thumbs Up
Will book for mod!!
cheers,
JJ
Post #209529 11th Sep 2013 12:03pm
Java Jungle
Had it checked today....apparently the smoke from the exhaust is when the DPF cleans itself. All mod. had been done previously and computer not showing any faults.
Can anybody confirm having similar issues?
Thanks,
JJ
Post #209877 12th Sep 2013 6:10pm
shalz
Has the smoke from the exhaust only happened this one time, in which case it could be a dpf regeneration? If it's happening regularly on hard acceleration then it's the issue Nick and I previously mentioned. If they've done all the mods then not sure what else it could be other than a separate oil or coolant leak? MY11 Vogue 4.4 TDV8 - "African Queen"
Post #209938 12th Sep 2013 11:40pm
Nick Ground
Never noticed the DPF cleaning itself in the past but I tend to do quite a lot of long faster journeys. If it blows out copious amounts of smoke regularly then its unlikely to be DPF. How many miles has your car done? Mine started to show the turbo problem at about 9k on both cars. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
Post #209956 13th Sep 2013 7:35am
Java Jungle
This is the second time I've noticed on hard acceleration, the car has now 8500km.
JJ
Post #209992 13th Sep 2013 9:54am
Java Jungle
As mentioned before I was told that the smoke from the exhaust wa due to the DPF cleaning itself...but today for the very first time after 6 month a warning sign turned up: Exhaust filter almost full Shocked
Getting fedup whit this Exclamation
JJ
Post #211359 20th Sep 2013 6:45pm
Do you regularly give it a good "Blast" ?
Post #211363 20th Sep 2013 7:13pm
Java Jungle
No, not regularly....maybe that's what I should do Cool Never had this with the L322/MY2010
JJ
Post #211396 20th Sep 2013 10:05pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
It's in your book , regen on the DPF , loads of cars now having same issues not just land Rover , you need to drive it to get DPF hot usually on motorway for 20 mins at 70MPH etc , but you will see this in your manual. same on 3.0 , etc etc
Also i have noticed over the last 2 years that better fuel if you do a lot of town and short journey stuff also helps the DPF Far to many gone...
Post #212371 26th Sep 2013 7:00am
My wife has a VW Tiguan and as she uses it for school runs I have to give it a blast up the Motorway every few weeks to avoid the MIL coming on...
Post #212378 26th Sep 2013 8:09am
Java Jungle
Thank you guys Thumbs Up
JJ
Post #212477 26th Sep 2013 5:43pm
