![]() | Home > Technical (L322) > Suspension fault |
| hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165
Have you started the car the next morning ?
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
They all settle and if ground in not completely flat car will level so different measurements either side! |
| Jdhall78 Member Since: 11 May 2013 Location: Surrey Posts: 10
Hi Thanks for the quick reply
Should not have licked it |
haha just spotted that i knew thats where i went wrong |
so any idea what could be causing the messages? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
have a read/search in the tech and maintenance sections for eas and suspension faults, there's loads on this subject .. .. ... - .- -.
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
If you drop your fattie down to access mode then raise it to off road height does it go up ok? Does it say "raising slowly"?
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
^^ should raise smoothly, best to do it after a run, as the compressor will have fully charged the air reservoir. Once you have used all the air up it will go up slowly, so dont expect to repeat access to offroad over and over again without it displaying raising slowly.
Ok just went on a 70 mile run no issues until 58 miles then suspension inactive max speed 30mph no lights on height selector.
see if you can find someone local to clear your fault codes first... free use of "RSW" all comms to anyone nearby |
| Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193
Yes there is one only 5min from you Its a really good one Called addellstone garage on brighton road its behind the car dealer so not the car dealer but behind it |
Ok spoke to Addlestone garage and they gave me the number for a guy called Barry at Thameside Automotive in Shepperton.
