Home > Maintenance & Mods (L322) > LED Bulbs
Page 4 of 5 <12345>
vallef
Sweden 2004 Range Rover Vogue Td6 Java Black
RunningCANBUS 501(W5W) sidelights for 6 months - All OK
I put in CANBUS 501 LEDS from HIDs Direct (£15) on ebay about 6 months ago, all is well also passed Swedish (MOT) car test.
However, the rear reversing LED lights (5050 SMD CANBUS H6W, cost £10) were too long so I could not put them in. Shame need as much light as possible in dark winter months.
I much happier with the LEDs, they match the Xenon headlight colour and seem to be just as bright or even better.
Post #211603 22nd Sep 2013 10:02pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Nick, I've just bought a couple for no plate, will report back.
Post #211719 23rd Sep 2013 3:42pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I really fancy some rear LED number plate lamps for my 07....did anyone source anything that worked?
M.
Post #296480 1st Dec 2014 11:46pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
hi plenty on flea bay. just make sure they are error free. Thumbs Up
greg.
Post #296493 2nd Dec 2014 7:12am
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
Is it easy to fit the sidelight led's. I've heard that you need to take the headlight unit out Shocked
Post #296740 3rd Dec 2014 10:04am
marcoos_1
oh no....don't say that........
Post #296745 3rd Dec 2014 10:49am
marcoos_1
Just fitted mine as they arrived today. I looked at the manual and thought sod this, no way I'm getting my hand in there without taking the unit out. So out they came. It was a 2 minute job and they look brilliant........
Well chuffed. Got the pair for £7.99......what a difference to the look of the front of the car. Just going to order a couple of LED Festoon bulbs for the rear number plate lights now.
Post #296876 3rd Dec 2014 10:52pm
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
Did the LED side lights on mine too last night.
You do need to take the head lights out, but really easy, and instructions are in the hand book. 3 screw across top of grill to remove that, then 3 nuts, (think they were 7mm from memory) around each headlight. Easypeazy.
Also did the interior lights in the upper tailgate. Has made a massive difference when hunting in the boot in the dark.
(Finally, I did the side lights on the Disco 4 - they are now brighter than the main headlights!!!)
Dean 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #297065 4th Dec 2014 9:39pm
marcoos_1
Interesting.....what bulb type was it you used for the interior ones you changed? I've thought about buying the kit for the interior lights......
Post #297080 4th Dec 2014 10:57pm
Dean
I used the same ones as for the side lights
Not sure of the quality, but I used these and they work fine (some where a tightish fit in the connector and it does matter which way around you put them in the connector).
http://www.ebay.co.uk/itm/10X-100-ERROR-FR...OC:GB:3160
They are supposedly the correct fitting and spec to fit in the overhead interior lights for driver and passengers, but the round head of the light is actually to big to fit through the hole in the back of the lens unit.
Post #297086 4th Dec 2014 11:27pm
marcoos_1
That's lucky then.....I've go two left.....they'll be going in there tomorrow!!!
Post #297099 5th Dec 2014 12:32am
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Would I be right in guessing that the indicator and reversing light bulbs are the same 501 LED fitment as the sidelights? Might as well do the lot at once if I'm buying sidelights... NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #354691 30th Oct 2015 10:57am
Dean
The same bulbs don't physically fit in the reversing light and no alternative LED seams to be available unless you are able to fabricate something with small LED panels - various threads on the subject else where.
Not tried the indicators though, so don't know about them.
D 2006 FFRR TDV8 Vogue
Post #354697 30th Oct 2015 11:28am
@mat,
Post #354701 30th Oct 2015 12:48pm
mat777
thanks stan Thumbs Up
On the subject of bulbs, one thing that has always confused me about mine is why it has xenon dipped beams but halogen mains - seems a tad counter-intuitive and its noticeably not as bright as our bmw with xenon mains NW060
Post #358244 23rd Nov 2015 2:36pm
Page 4 of 5 <12345>
