Home > Maintenance & Mods (L322) > Bonnet Release catch
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Have had a wee problem.
I pulled the bonnet release lever this morning for the
weekly chaecks and snapped the cable.
Is there anyway to get the bonnet open?
Cheers in advance. 15MY SDV8 Vogue SE
Post #21164 27th Jun 2010 2:53pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
take off the panel where the catch is and see if you can pull the wire with a pair of pliers 2002 td6 vogue, 06 supercharged facelift
Post #21167 27th Jun 2010 6:28pm
Jem0911
I can't get any of the cable it's back up in the guide tube.
I'm in bother I feel. 15MY SDV8 Vogue SE
Post #21168 27th Jun 2010 6:34pm
mzplcg
Not sure on the FFRR but I did a similar thing on my D3. Sorry to report that I needed a ramp so I could poke my arm up from underneath and persuade it with a screwdriver. The worst bit is there's 2 catches on these large bonnets. Mucho scratched arms and skinned knuckles I'm afraid.
If you can get to the cable anywhere along its length then you can give that a good tug (it's broken anyway) which has been known to work - my old Jensen Interceptor, but of course, other stuff in the way might get damaged. For sure it'll break those clips which hold it in place.
How far up has it actually broken?? If it's not too far you might be able to cut back some of the outer which is inside the car and then pull on the inner with some molegrips.
Best of luck.
Post #21175 27th Jun 2010 7:54pm
Jem0911
Sorted
Dug thencable from the outer cover.
Mole grips.
Booked in for repair and further hoses so I don't need to check daily. 15MY SDV8 Vogue SE
Post #21294 29th Jun 2010 8:39pm
