![]() | Home > Technical (L322) > Losing water |
| tony1kenobee Member Since: 07 Jul 2012 Location: SOUTHAMPTON Posts: 145
Many thanks to you all for your pointers.anyway.i had a test done from the radiator where the water turns blue if co2 is present.nothing changed.somthats good news.another pressure test.no problems there.ive just done a 500 ,yes 500 mile round trip to Wales and absolutely no problem at all.no water lost.im completely at a loss as to what it is.someone suggested a possible air lock?.ive still got to put it into the Indy coz the rocket cover gasket is leaking and i need new lambda sensors post exhaust but apart from that the car runs like a dream.ill have to check again in a few days.again many thanks for all the replies that you kindly sent.regards .Tony |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Glad to hear that it is unlikely to be the head gasket !!! It could still be something simple as a crack in the coolant tank or a hose or some small opening that closes up when the engine gets hot. MY 2010 5.0 SC Galway green and sand interior!!
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
thats good news! makes things much simpler. 2 options: a) ignore untill leak source if obvious b) look harder. if you choose b try not to keep taking the lid off the tank to check the level. if its a small leak it will need the pressure in the system to force the coolant out. when you take the lid off that pressure is gone. good luck and keep us posted. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| All times are GMT |
