Home > Maintenance & Mods (L322) > Powerfold motor on a 2007 FF |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Hi all, sod getting my air suspension working ( refers to another post I made under Technical!)
22nd Sep 2013 11:11pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Cant help on first bit but I don't think 2010 mirrors will fit. Bare in mind freelander 2 and discovery 3 mirrors are the same in appearance so if you look for a freelander 2 mirror might get it cheaper Present :2008 TDV8 HSE
22nd Sep 2013 11:50pm |
Cheers Craig, never realised that, a good option then. Will try the motor first, worth a play as it might be something or nothing, eg microswitch etc. |
23rd Sep 2013 12:21am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
23rd Sep 2013 12:30am |
Took the mirror off completely to have a good look, doesn't seem possible to open the casing at the swivel joint. Craig had earlier confirmed that you can't take the back cover off either. I tried removing the glass and motor, still doesn't help. The mirrors are assembled then plastic welded.
25th Sep 2013 8:06pm |
