Home > Maintenance & Mods (L322) > Too much oil?
J90
France 2006 Range Rover Vogue Td6 Java Black
Too much oil?
Quick question - I've changed my oil today but overfilled it (according to dipstick) by about 1 to 1.5 litres.
Will it be OK or should I drain some of it off.
Ta ...
Post #212529 26th Sep 2013 8:41pm
Drain it off as it's not good for the crankshaft or con rods slapping it when it's running Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #212532 26th Sep 2013 8:46pm
to much can be as bad as having not enough..i'd drain some off to be safe. ... - .- -.
Post #212534 26th Sep 2013 8:46pm
J90
Thanks chaps, I'll drain some of it away.
Fortunately I have a vacuum oil pump (as per another post) so it will at least be an easy job to do Thumbs Up
Post #212543 26th Sep 2013 9:20pm
+1 as above...
Post #212544 26th Sep 2013 9:22pm
Had my Porsche serviced at the main dealer and they overfilled the oil, 2 weeks later oil was spewing out the crankshaft oil seal. Gearbox had to be removed sump dropped to fit a new seal, an expensive mistake for the main dealer
Post #212551 26th Sep 2013 9:35pm
ebajema
A little overfill (few mm above the max cold mark) is not a problem but 1 to 1.5 liter is likely to cause some issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #212562 26th Sep 2013 10:22pm
