![]() | Home > Maintenance & Mods (L322) > " air sus inactive after brake change " |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
You need to turn the steering from full lock to full lock at least once to reset it. |
| greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157
hi
^ Yes I see you did it twice... |
Did you move/break/interfere with a height sensor when you where changing the pads? |
Have you checked the height sensors in the wheel arches? |
not that i can remember, that's something i haven't checked..just getting ready for work but i will have a butchers when i get back...i hope its something as simple as that,fingers crossed... thank you for your help..i will get back on here and let you know later on today.. |
Get the codes read as this should identify the problem including the sensors. |
hi everyone,further more to the ongoing saga,i got home this after noon and turned the steering wheel full lock one way and then other so i had a good view of the level sensor,i had a little prod to see if anything was loose or broken but both are attached to the lower suspension arm and both have the electrical connector connected to them..in regards to the codes that would enable me to find the problem how do i get them to come up up as i don't have a iid tool...any suggestions anyone.. |
| adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204
to save your time and muscle power
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
RSW All Comms, Hawkeye, Faultmate, Solus, TESTBOOK or an IIDTool |
Any half/decent code reader that supports BMW group will do
| All times are GMT |
