![]() | Home > Technical (L322) > Towbar electrics? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Trailer light does stay on. Perfectly normal. Mine does the same, thinkit is different on earlier cars where it did flash.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Don't worry - it's perfectly normal - mine does the same - no need to get it programmed..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Mine flashes in time with the indicators.
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 ![]() ![]() |
Mine too and perfectly normal. I find it reassuring as you know the trailer electrics are definitely connected. |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 ![]() ![]() ![]() |
Ian and BigBoy,
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Mine was fitted by a main dealer
Mine was fitted by the main dealer. They fitted the towing module, and if I recall, they just had to activate it, ie switch it on on the ecu. It didn't need any reprogramming as far as I remember.
My towbar and electrics were on the car when I bought it and as it was an ex land rover owned vehicle I assume it was fitted by land rover.
tobylo Member Since: 26 Jul 2012 Location: Dublin Posts: 52 ![]() ![]() ![]() |
My light stays on when trailer connected. As Big Boy R44ROV says maybe the manual needs to be updated. I know in the faultmate there is a setting for tow bar electrics installed. Just a yes no drop down box if i recall, then it's saved to the ecu. Sounds like it's working fine to me. |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
hi I have 2006 rr & tow a caravan the green light stays on when van plugged in If van flasher lamp goes out car flashers will flash quicker & message will come up on dash . Rest assured your car is how it should be . Merry christmas to all. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
hum I have an 06 & tow a horsebox and occasionally open back trailer and i have..........
