![]() | Home > Technical (L322) > 5 min into every drive.air suspension inactive hdc abs brake |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
Swapped out the ABS sensor, what a nightmare when they're seized up... That did not remedy the problem. |
was yours an intermittent issue? or lights on all the time? Very excited to hear it could be something so simple. although I don't see this part in the rave manual. Thanks for the post... I noticed today it more often than not the errors happen during braking, interesting. Anyone know more about this brake switch? sounds like it can either be a nightmare to access or a breeze, wouldn't mind shotgunning this issue with that replacement. thanks again |
What exactly does the brake light switch do? I unplugged it and removed it, looks like its magnetic. While it was pulled I decided to drive down the street to see if I instantly got the errors I'm familiar with... Didn't trigger anything, nor did it seem to have any affect on the brake lights... Unless it controls only the 3rd brake light, but I couldn't see that one.
tonybm730 Member Since: 24 Mar 2010 Location: wigan lancs Posts: 21 ![]() ![]() |
Hi mate had mine diagnosed at the garage were i take my car, i'm not very tech minded so the guy told me that the car thought the brakes were on all the time, even though they wern't he said this was sending all the wrong messages to the other systems. So within 5 mins of driving on they came, HDC INACTIVE, ABS NOT WORKING, BRAKE WARNING LIGHT, AIS SUSPENSION NOT WORKING ,AND ALSO TRANS FAILSAFE MODE every time i went out. He put his diagnostic pad on all pointed to brake pedal switch the one near the brake pedal itself took him about 10 to 15 mins fiddleing all done never had a warning light since hope this helps mate
Greatly appreciated, when I pulled mine yesterday it looks like the previous owner had some hack mechanic working on that area, screws/bolts missing and the switch itself was not in perfect condition. I order the switch which comes in friday, we'll see what happens. what year is your range that had this issue? Thanks again. ~Brad |
Hey Brad my fingers are crossed for you hope it works as well as mine did i have a 4.4 02 Vogue |
Thanks for the posts tonybm, greatly appreciated, this forum is great ![]() I'm actually going to pick up the switch now, I'll post back in a day or to with the results. Thanks again! |
Well the brake sensor didn't remedy the problem, during the test drive with the new sensor I found myself close to an independent land rover shop, so they were kind enough to plug it into test book and diagnose the problem...
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Did this work? |
