Home > Technical (L322) > Were the **** is my Jump Start Live Connector
jonlewis
2007 Range Rover Vogue TDV8 Buckingham Blue
Because it isn't where the manual says it should be !!
There is no Positive Terminal on the bulkhead near the battery that I can see and the cable that comes out where it says it should be seems to go off into the depths of the engine.
Jon 2011 Stornaway Grey 5.0SC Autobiography
Post #212829 28th Sep 2013 9:51am
I thought they stopped doing them around 2007.....
Post #212831 28th Sep 2013 10:07am
My 56 plate had one, but my 08 one doesn't.
Maybe they thought they had sorted out the battery problems by then and it didn't need one? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #212834 28th Sep 2013 10:42am
I put an Anderson Connector on instead
Pics here Thumbs Up
Post #212837 28th Sep 2013 10:55am
wealy
My 55 plate had one and the 10MY does not.
Post #212873 28th Sep 2013 1:27pm
I understand you can buy the necessary bits from Dan@Duckworths and retro-fit them to your car.
Not a big job. Thumbs Up
Post #212884 28th Sep 2013 2:26pm
jonlewis
Thanks everyone.
It does not help that the manual say something like "you and your children will die a horrible flaming death if you use the connector on the battery, please use the remote connection"..... and then remove it so you have to use the one on the battery.
LR Assistance came out in the end anyway as my booster would not do the job. Turns out that when the dealer replaced the battery after the alternator failure they put in a 800amp one.
Evil or Very Mad 2011 Stornaway Grey 5.0SC Autobiography
Post #212888 28th Sep 2013 3:00pm
Sorry to here you have had problems Jon... Sad
Post #212938 28th Sep 2013 9:07pm
