Hi guys,
I'm looking for a bit of advice with my td6 about a month ago she started running a little rough. So I did a leak off check and found that injector no1 was leaking double the amount of the rest (they where all within about 10%) so I replaced that injector. It made a very small difference with the running.
I have checked the fault codes relating to the engine and after clearing them and driving for a week I got the following faults ; 3505
0404
1613
1df5
3515
The main problem I have is I can not find the code translations. (None of them are p codes).
Also after the reset she runs very lumpy until about 100miles later, I'm guessing this is injector trim compensation?
One final thing is, as far as I'm aware I can't view the injector trims with the Iid tool, can a faultmate read these?
Any help will be very much appreciated.
Kind regards, Luke
