![]() | Home > Maintenance & Mods (L322) > Snow Foam Deal |
Via Detailing World UK, in readiness for winter and to try and keep on top of the cars, I've just ordered the following stuff that I've never tried before:
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I would wait if you can. That way you get to see if the stuff is as good as they say. Maybe try the method of just spraying the foam on 1st and spray off to see how well it works without using a mitt.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6820 ![]() ![]() ![]() |
It definitely doesn't work on black paintwork! |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Great gadget to use these but remember to flush the lance through with water after use as they can get blocked up with the foam solution. 2021 P400 Silicon Silver AB
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2620 ![]() ![]() |
Or green, or red, or white, or gold, or silver ... Haven't tried the Magifoam but I can't imagine any non-touch foam which isn't pretty aggressive can work on road grime. |
Miracles not anticipated but lots of DW UK members recc this process so hopefully it will help keep on top of things during winter and will loosen some grime/ grit before using a mitt. Soon find out |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
@Pld; Think you've got the attitude all sorted. It won't leave a pristine clean car with no touch- not without some kind of awesome sealant like C1 first but as a winter "maintenance" thing to get the worst off along with a pressure wash it's pretty good.
The foam kit arrived yday (within 48 hours of placing the order/ 'free delivery').
Thanks for the update pld118.
@Prop.
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
You don't have any before and after pics do you? |
No before/ after pics sorry |
Before - dirty, after -clean! |
