![]() | Home > Technical (L322) > Exterior A-Pillar Trim removal |
| a016738 Member Since: 10 Jul 2013 Location: Massachusetts Posts: 8
A pillar exterior trim
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
Pretty sure the trim is fastened on using the same method throughout the model years. Four white nylon push fit clips under the front of the trim, four black nylon expanding rivets up the inside edge in the door reveal. Can't see why you would need to remove any internal trim at all, the piece fits on the outside of the rubber seal that runs around the door frame. Get an A pillar fitting kit - 4x white nylon push fit clips, four expanding rivets and four of the little sealing caps that fit into the metal of the pillar, the expanding rivets are pushed into these. |
super helpful..thank you! I think maybe the manual's intent was to push the white nylon clips out from the inside versus just pulling them out. Glad to know it's as easy as that.
The easiest way is to push the centre pin right through the expander. I have heard somebody who drilled a fine hole through the pin for a screw to pull the pin back out, but it's not worth the bother- as then you have a hole in the pin. That's why you need four new seals for the expanding rivets - the action of pushing the pins through destroys the little seal- it looks like a little top hat. |
Makes sense...thank you!! |
| All times are GMT |
