![]() | Home > Technical (L322) > dpf filter? |
| adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204
NO no DPF on TD6 or early TDV8 |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
To avoid confusion, there is an oil breather filter that does need changing every 30K or so
No confusion here the question is abut DPF filter
| ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341
So what is the large thing in the exhaust just south of the turbo? Mine was pretty blocked.
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
Also in Germany NO DPF possible, so the TD6 may not drive in some towns, because we have red,yellow and green stickers for towns, mostly only green is allowed. The TD6 is like the BMW X5 3.0d, he has DPF..., but there is no technical possibility to Change parts from X5 to TD6. Green Stickers you can also buy at some well educated garage owners... |
Catalytic converter all modern car have one |
Didn't think for a moment you would be confused adigorn |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
Thanks guys, just what I wanted to know, DPF's can be expensive when they go wrong,so glad the td6 and early tdv8 are missing them |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
When (what year) was DPF fitted to the TDV8? |
| All times are GMT |
