Home > Technical (L322) > Egr
Jason1608
Egr
Hi all new to this site , brought vogue tdv8 86000 miles, smoking like mad took to main dealer today said it was egr units on both banks, £ 1085 to fix asked them i asked them if it could be turbos but they said they have to do this first before they could tell does this sound right to anyone.
Post #213494 1st Oct 2013 9:23pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
Hi Jason.
Do you have a warranty on the vehicle? I got mine done under warranty as after only 2 weeks the same problem occurred.
I'd say you'd definitely notice if it was turbo. Egr valve replacement sorted the black smoke out for mine.
Post #213503 1st Oct 2013 9:37pm
If its covered under warranty, you might consider an independent. I was quoted £600 to replace both a couple of weeks ago. Got - 2017 SDV8 Autobiography in Loire Blue
Post #213508 1st Oct 2013 9:43pm
Jason1608
Thanks for quick reply did your oil level drop because of the problem.
Post #213517 1st Oct 2013 9:51pm
adigorn
they should be able to tell from fault codes - or dynamic test
split turbo pipe will smoke as well (plenty of black smoke of full throttle)
however if you are rapidly loosing oil you should stop driving it
Post #213527 1st Oct 2013 10:02pm
Jason1608
Thanks for advice would dread to think of cost if turbos were broke. Would have to find Indy to do it
Post #213530 1st Oct 2013 10:10pm
The Indy I use only suggested I replace mine and only as a result of investigation a noise I was hearing. No drop in oil level.
After reading several threads, I went down the route of a diesel additive (EGR cleaner), which seems to have done th trick go now. Got - 2017 SDV8 Autobiography in Loire Blue
Post #213552 2nd Oct 2013 5:42am
