Home > Maintenance & Mods (L322) > SRS Light
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
SRS Light
Guys and Gals
Just had my L322 in for an MOT, all good apart from the SRS light, what a PITA to get sorted, anyone come across the same issue, its been in there 2 weeks, with a trusted indy 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #213969 3rd Oct 2013 10:54pm
If I'm not mistaken, you can pull the fuse on the SRS system and the SRS light will go out.
You can then present your car for a re-test and it will not be failed for this item, you will only have an advisory that the SRS light doesn't function.
ie to pass an MOT the light either has to function correctly or not be on all. Rolling Eyes
If you do pull the fuse you will appreciate the SRS system will not be operative ie no airbags, but at least you will have the choice of using the car.
No worse than at present as the SRS light was permanently on the SRS system was in-operative anyway.
Can't help as to why the light is on I'm afraid.
Post #214018 4th Oct 2013 9:06am
wealy
It will be a short with the connection to one of the airbags. had this with my son's Disco. The offending connection was under the passenger seat.
Post #214104 4th Oct 2013 3:00pm
