![]() | Home > Technical (L322) > Message: "CHECK SIDELIGHT" ? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Comes up on start up, turn on sidelights, get out and check, all working.
Joe its the "Bling" warning mate.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
those errors normally come up when theres a faulty bulb or a non-canbus bulb fitted..i suspect that one or both bulbs have burnt out their canbus circuit....or the bulb just needs re-seating. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
+1 for ^ |
Thanks guys, I'll have a play tomorrow .
Had a chance to have a look. It was both LEDs, whether they have both gone at once, or it took both to trigger the fault, but see from the picture where the problem was:
i've brought a fair amount of leds/smds and nearly all get dry joints within months of use, but a quick dabble with a soldering iron and they work ok again... ... - .- -.
Stan recommended them (the ones in the photo) |
i did |
The bulbs I used are very bright, almost brighter than the H7s in my foglight DRLs, don't give a canbus message, but blink every 20 seconds or so (this must be the canbus test) .
you can switch off the hot monitoring with an IIDTool, but you probably knew that already.. ... - .- -.
Always too embarrassed to ask what hot and cold monitoring is |
thats when the ecu checks to see if the bulb is ok..cold on start up and hot whilst engine running..
