![]() | Home > Technical (L322) > L322 2003 TD6 AUTO Vogue Engine cuts out |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 ![]() ![]() ![]() |
Pm me your Email address and I will send you the Wiring Diagrams |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8483 ![]() ![]() ![]() |
Sounds like a sensor fault, possibly the rail pressure sensor. Or something like that, and it maybe only throws a wobbler when it gets warm. The fact it runs fine for a while would suggest the mechanicals are ok.
Taximan2011 Member Since: 15 Jul 2013 Location: Somerset Posts: 15 ![]() ![]() ![]() |
but which sensor New L322 Owner - |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
If you can get it on a test when it first cuts out it will probs tell you it's crank shaft or camshaft sensor had a few cars do it but only when warm once it's cooled down they usly start |
Thats the million dollar question, and may be trixy to find out if there are no fault codes showing. Do you have a good indy locally?
Ruled out crankshaft sensor because I thought if it was that then it wouldn't restart and surely that would come up as a crankshaft sensor fault as its a pretty important sensor. New L322 Owner - |
surely common rail pressure sensor is high pressure sensor..and the fault codes were all low pressure faults. New L322 Owner - |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
not necessarily - but i agree with you here
BUT you have HP fault logged
so listen to good advices ![]() Last edited by adigorn on 5th Oct 2013 7:56pm. Edited 1 time in total |
HP fault logged ?? New L322 Owner - |
edited |
Thats what made me think cr sensor. There is nothing that can't be fixed with a hammer😜😜
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 ![]() ![]() |
RAVE here: http://www.fullfatrr.com/forum/topic17363.html
