Home > Maintenance & Mods (L322) > Rust Proofing
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
This is great advice thank you so much. Really want to prevent the rust getting worse. Looks like this winter is going to be a harsh one again so need to do this pronto.
I suppose the other questions are, do you use black or clear and how does the shultze gun work?
Post #214686 6th Oct 2013 6:42pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
I use the black stuff,shutz guns are usually air fed via a compressor,the waxoyl kit is a pump up thing like a garden sprayer,you can get a kit from halfords then just buy a refill tin if you need any more.
Post #214777 6th Oct 2013 10:13pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
If you dont have a little compressor then the pump up ones work pretty good too, either way easier & better than using a brush & I always use the blackstuff Very Happy Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #214784 6th Oct 2013 10:38pm
crookedm
Fantastic. Thanks for all the advice. Another shopping list created!
Post #214789 6th Oct 2013 11:10pm
Fame
Portugal 2002 Range Rover Vogue Td6 Java Black
I know you guys in the UK just LOVE Waxoi but I have not had such a good experience with it when living in Amsterdam' even when having it done by specialists and all their " guarantees" Because it is sprayable, it may be advantagous to spray into body cavities if accessible to tubing. I have found these so- called experts even resort to drilling small holes into chassis sections to get the product into hollows. And later I have found RUST around these openings, even if " sealed " with rubber plugs. If you want to use it do it yourself and don't skimp on material. I now hesitate before drilling into ANY metal structure which is stressed, after reading " Nnuts, bolts and things" by some yank I think the name is Carrol. (He maintains that aircraft have even crashed due to failures of FALSIFied fasteners which had " hardened" markings and then found their way into the fasteners market internationally.)
For metal which is exposed , flat surfaces, I think the best is POR 15 " paint " It forms such an impenetrable coating ( after treatment with their " metal prep" that O2 can't penetrate the barrier. Unaffected by oil, grease etc but must have their topcoat if exposed to sunlight. Then apply a shutz protective layer.( Rubberised or flexible ) I was told by a restorative guy, that they use it by painting it on, acpplying a fibre glass tisue over it, another layer of POR and it then covers multiple sieve-like holes in thin sheet metal and this is as durable as the original metal, as POR is called a paint but it is in fact a " chemical "( i prefer to cut out and weld though!!!)
Much more worky with POR, but I think it will be more durable than Waxiol OR other such coatings. Will update this posting in about 10 years time, when I have driven my by then resored '59 220S Merc. Which I will be covering in POR. Range Rover Vogue TD6 2002
Defender TD5 90Hard Top 2001
Range Rover Classic TDi 1994
Mercedes Benz 1959 220S Sedan
Post #214807 7th Oct 2013 8:41am
I did the Defender using Waxoyl and wouldn't nuse it again, too messy and the applicator kit from Halfords is rubbish.
Next time I will use Schutz and use the air compressor. There are kits on eBay for about 6 cans of the stuff and the airgun too.
http://www.ebay.co.uk/itm/Stonechip-Shutz-...51b0a9f5a0
http://www.ebay.co.uk/itm/DINITROL-RUST-PR...33766cc1e6 Discovery 4 HSE
Post #214848 7th Oct 2013 12:54pm
