![]() | Home > Maintenance & Mods (L322) > leakage |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
Hi
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
Can we have a bit more detail....Engine type? Petrol/Diesel/TD6/TDV8/V8 age, model, mileage. |
03 td6, left side when sitting in the car.
If it isn't dripping on the ground it could be oil from previous filter changes. Some mechanics can be rather messy |
Oh, but its dripping. -03V td6
You need to clean all the area and the above area and monitor it to see where the leak is coming from. I can't tell from the pictures if it's diesel or oil, maybe you could confirm |
Hi. I had some leaks. Not a clue if they're similar to yours but the attached thread will let you make your own mind up if you've not seen it before.
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
Could be power steering fluid,have you checked it lately???.the resovour is on that side on a td6. |
