![]() | Home > Technical (L322) > Weird Air con behaiviour |
The final stage resistor controls the fan speed so this won’t be your problem in this case. I would have thought it would be one of the motors in the heater unit have failed or is slipping. It could have just got itself confused, I think there is a reset procedure you can do via testbook/rovacom which may be worth a punt first? Take a browse through RAVE on the HEVAC system and how it works etc to get a good overview and work out with your symptoms where your problem lies.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2071 ![]() ![]() ![]() |
I can recommend a good guy to re-gas your A/C if you want his number. |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Yea PM me his number please.
Absolutely no part of that is due to low gas. ![]() |
