![]() | Home > Maintenance & Mods (L322) > Hose blew off Radiator today! - update |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
New radiator from Advanced Factors (Nissens) - old hose (the smaller one above the bottom hose) that runs down to the transmission cooler.
old hose more likely I had same on mine. Jubilee is your friend. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Agreed. It's when your coolant temp drops that you've got to start worrying. i.e. when there's no water in the system and your sensor is recording the air temp inside the pipe. Si. <This is my name.
http://www.fullfatrr.com/forum/topic13813.html?highlight=raymond
Jubilee Clips are your friend (again) |
I made it home safely, kept to @ 2000 rpm, had to stop twice in the first few miles to top up with a further 3 litres of water after getting the Low Coolant bong again and again. (Interestingly, no bong for specific gravity not being right?)
Rubber on Rad connector I think. Will picture mine tomorrow. |
Tackled the resolution today. Removed engine undertray then pulled hose off and caught most of the fluid that dripped from the hole in the radiator. Brought hose out under the car to inspect, removed clip and bent the legs in to give them more spring. Then several trial fits to observe correct location. Once I was positive the clip was in line with the recessed ring I clicked into place. Then just for good measure used a jubilee clip (hand tight) over the end nearest the radiator. This should stop the clip springing out (although it didn't last time) and exact a small amount of purchase on the inner part of the mounting.
I am not for the jubilee clip repair except as a 'get me home' measure.
should be perfect. ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Hi Steve
Hi Joe,
Ah yes. I toyed with the idea of chopping the end off, but could see I would have to get the hose really hot to soften it enough to get it to fit, so didn't do that, and agree with you about the ally strength too |
