Home > Technical (L322) > Major coolant loss/leak
steptoe
2002 4.4 V8 - Coolant leak from somewhere behind the engine, water pouring out from the gearbox area underneth the car.
Removed the top engine cover and had a look from the top of the engine but can't see anything as there's no room.
How do you get access to the area behind the Vee in the engine to have a look ?
Is the the pollen filter housing section removable ?
Tried looking from underneth but no hoses in sight.
Post #215478 9th Oct 2013 4:53pm
Dolphinboy
it's probably one of the rear hoses, which are a Censored to get to, but there is a wiki I think but do a search.
In addition, check your water pump at the front of the radiator. it's a common weak point. There should be a lot of brown water splashed around that area.
Post #215515 9th Oct 2013 6:35pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
this may help
http://www.rswsolutions.com/index.php?opti...;Itemid=78 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #215538 9th Oct 2013 7:46pm
yep pollon housing comes out. 2x 13mm (I think) nuts hold it in either side. remove the seal from the top and pull towards the front of car. Do this then report back. Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #215540 9th Oct 2013 8:05pm
steptoe
Thank you Daz and Rob .
Doesn't help i've all the LPG pipework and wiring in the way Mr. Green
Post #215554 9th Oct 2013 9:34pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Aha now we are getting somewhere
check the coolant hoses connected to the lpg cold reducer
Post #215600 10th Oct 2013 7:52am
steptoe
Re: this may help
daz62 wrote:
http://www.rswsolutions.com/index.php?option=com_content&view=article&id=420:range-rover-mkiii-rear-engine-coolant-leak&catid=54:mkiii-repair-videos&Itemid=78
That's the problem. That exact section of hose Thumbs Up
So no major dismantling required. Razz
Post #215676 10th Oct 2013 3:37pm
steptoe
Popped into wimbledon land rover and 45 minutes later i'm back home with the part and 15 litres of new coolant. Thumbs Up
Part number JHC000081. Cost £7.31.
Another 30 minutes and it should all be fitted, bled and ready to roll.
Very Happy
Post #215681 10th Oct 2013 4:37pm
daz62
Fantastic stuff.
What a comfort it is to have a great resource of information on this website. Kudos Martin for keeping it running Thumbs Up 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #215695 10th Oct 2013 5:55pm
