Home > Maintenance & Mods (L322) > remove tv tuner
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
remove tv tuner
Just bought a hybrid tuner (Thanks Craig) and find myself scratching my head at how to fit it.
I've searched the forums (but probably not as much as I should) and find myself in this position.
So question is how do I remove the analogue tuner so I can fit the new hybrid as I cant see any other screws or fixings???
Thanks in advance.
Mike Currently - 55 FFRR S/C and loving it
Post #215916 11th Oct 2013 6:06pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
The TV tuner is screwed onto the backing plate from the other side, so you needs to take the tuner & backplate out then separate them. I used two pieces of light angled aluminium 25x25 mm to make new mounting bracket for the new tuner & drilled them to match the original mounting holes on the steel back plate. It was a straightforward job and only took about 30mins to mount the new tuner onto the original back plate.
Make sure to mount the new tuner so as the connection ports face upwards, the same as the original one! Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #215918 11th Oct 2013 6:18pm
kruger2002
Thanks for the swift response B9er. How does the backplate come off?
Do I have to dismantle the whole setup or are the bolts there to do it straightforward. Currently - 55 FFRR S/C and loving it
Post #215921 11th Oct 2013 6:27pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I just fixed my new one against the original using velcro, then swapped the leads over.
Post #215922 11th Oct 2013 6:34pm
B9er
Pretty much the whole setup has to come out to release the back plate. Some people just wedge the new tuner down the side of the old one and make do with that. I preferred to make sure it was well secured and didn't see any point in lugging around the old tuner. It's not difficult to dismantle and reassemble the electronic grub bins and their mounts. The whole thing start to Finnish took me just over three hours. Should've been old enough to know better...doh!
Post #215923 11th Oct 2013 6:35pm
kruger2002
I've got the RSE fitted so looks like the whole lot is coming out.
Just testing it though and with all the plugs in I'm getting nothing out of the main screen just a flashing power button and the LR screen!! Currently - 55 FFRR S/C and loving it
Post #215924 11th Oct 2013 6:40pm
When you plug the analogue tuner back in does everything work as it should? Previously..
Post #215937 11th Oct 2013 7:52pm
kruger2002
Embarassed
In my haste to check everything I forgot to plug the optical rse box back in.
Whistle
I'll take the rest off tomorrow and refit. Currently - 55 FFRR S/C and loving it
Post #215938 11th Oct 2013 7:57pm
Thumbs Up Previously..
Post #215940 11th Oct 2013 7:59pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Is this what I need to sort my tv out its still on analogue and I want it working again what do they cost
Post #215943 11th Oct 2013 8:28pm
kruger2002
It's what I ended up doing.
Cam tech Craig sorted me with a hybrid tuner and as I mentioned I've the oem rear screens. Currently - 55 FFRR S/C and loving it
Post #215970 11th Oct 2013 10:19pm
steve9bug
I don't have rear screens but I am on a touch screen sat nav
Post #215973 11th Oct 2013 10:27pm
B9er
The hybrid tuner works well, RSE or not. If you have access to some form of coding, IID, Test Book etc, programme the vehicle with the hybrid TV option. It will still work if you don't, but won't list a TV tuner error code if you do Very Happy Should've been old enough to know better...doh!
Post #215982 11th Oct 2013 10:56pm
kruger2002
Update time
Ok so after missing out a step Whistle I had the full works back last night including tv tuner but didn't have time to fit it properly just lay it on the side.
This morning I decided to take it all apart and fit properly where the existing tuner is.
All done but in checking I got the flashing power light again.
Banging Head Banging Head thinks I. I thought I'd connected everything up.
Bit of a break with family and set back to it this afternoon.
Only to find after stripping it all apart that all the cables had been replaced.
Back together again (checking twice cables have been fitted) but still the blinking power light.
I thought I'd be able to do some things on this motor myself but hadn't couldn't on needing black magic to cure faults.
After the cable out cured the last episode what else could this be?
I think it's still related to these as a hen looking at the optic cables I'm not seeing any light coming out? Currently - 55 FFRR S/C and loving it
Post #216144 12th Oct 2013 9:13pm
Big Boy R44ROV
Kruger. Pop round tomorrow if you like. We'll tackle it together if it helps Thumbs Up
Post #216166 12th Oct 2013 10:08pm
