![]() | Home > Technical (L322) > Unexplained battery discharge???? |
| terex48 Member Since: 06 Feb 2011 Location: Scotland Posts: 8
I had a battery drain problem and found out it was the head lamp wiper relay , I pulled the fuse and have not had the problem since , I noticed it first by the wipers , they were not parking properly ( touching the bumper) I adjusted it then it was touching the bumper again . Not changed the relay yet as it is in behind the dashboard . 2004 Range Rover Vogue TD6
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
If you put the fuse back in they should park propperly, there is no manual adjustment you can do with them, they have to sense that they are "home"
| elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713
I'm thinking sensor. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
| Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165
Well stealer says they did a software update during the last visit, and a month down the line the discharge hasn't happened again. Touch wood it's fixed.
| Jackofq300 Member Since: 11 Aug 2013 Location: Dart ford Posts: 45
| All times are GMT |
