![]() | Home > Technical (L322) > Full tank..... Empty Tank..... Full Tank! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
edit.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
i reckon this will help,
This happened to me too I put it down to an airlock as it righted itself after about a week and has not happened since that was about 2 years ago |
Ok, thanks chaps.
After pretty much the whole day not working......
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
Did this ever come back?
yes it did, was fine for a time but in the end it started giving wrong readings, so i replaced the intank unit, and all is good again. There is nothing that can't be fixed with a hammer😜😜
I had a horrible feeling that was going to be the case.
Whats wrong with yours? The same as above or always reading 1/3rd of a tank? |
Goes from showing empty to full and then back to empty and so on every minute or so. |
I ask as there are two different problems sir... But if yours is showing the same symptoms as above then, that answers that... |
