![]() | Home > Maintenance & Mods (L322) > Looks like i have the Sticky rear caliper |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Friggin things squeals like a Banshee at times when the brakes heat up |
Well it will be a garage that will be doing it ….. |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
Oh aye, I forgot you have a "chap who does" |
PM sent mick |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I just had this done, near side rear was getting very hot. Cost less than two hundred quid and they included replacement disc and pad as well as the caliper, because I had only recently had discs and pads fitted. Geoff |
Was this from a local garage or stealer Geoff |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Is it getting hotter than the others? It could be there is no copper grease on the pads and they are just squealing ? Previously..
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Thats not bad at all Geoff, the calipers are cheap enough and easy to swap over but the discs can be a bit more tricky as you have to reset the epb.
@Mick:
Oddly enough an old mechanic guy told me to take it to a specific Indy who can wind back the EPB ….. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
Epb = electronic parking brake ? ... - .- -.
Adjusting the EPB isn't that difficult.
Aye, but is it hotter than the others when you stop?? Previously..
Nah not really Contra they all feel the same … ====================================
| All times are GMT |
