![]() | Home > Technical (L322) > knocky suspension? |
Change the droplinks my car is the same age as yours and the bushes on the droplinks were perishing these tend to make a knocking noise when going or gone that was at about 72K miles. Change for genuine if you can not expensive so worth doing anyway as tighten up car. Literally 10 mins a side . Rears longer due to access being tight but easly doable.
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Mine had exactly the same.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Lower ball joints look tight, no evident movement, so arb links first.
Does any one kkow who makes the lr ones?
Pretty sure Delphi are the OEMs thats what I fitted very good quality compared to cheapo versions I have seen. |
Cheers Connor. Will have a ring around to find a set. There is nothing that can't be fixed with a hammer😜😜
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Had a knock on the front of my VSE replaced both lower ball joints with delphi units as there was visible movement on the driver side.
At the dealer at the moment. They have put it on the ramp to have a look. There is nothing that can't be fixed with a hammer😜😜
Hokey day, garage reckon the same.
Ok.
Part number
