![]() | Home > Maintenance & Mods (L322) > Fuel Pump & Level Sender assembly WFX000160G |
WHich pump are you talking about Declan, there are 3 fuel pumps on the TD6
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
The lift pump in the fuel tank can be replaced by a BMW unit. I bought one from eBay and fitted it into my existing sender plastic housing. It was still working perfectly over a year later when I sold the car. Much much cheaper than buying the complete assembly |
Misfit Member Since: 24 Feb 2013 Location: Adelaide Posts: 12 ![]() ![]() ![]() |
It the pump in the fuel tank with the sender unit, B9er do you remenber which pump you bought for it,do you have a number off the BMW fuel pump unit ?.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Have a look at this
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I still need to sort mine out. I've had the car nearly 5 years and have just kept it over half a tank at all times |
This is where I bought mine! As I said its a straight swap into the plastic housing.
I'm not sure what I need. The car normally cuts out at around 75 mile range with just under 1/4 tank showing. I'm told there is a pump that transfers fuel from one side of the tank to the other- would that pump be the offending item? |
Highly lightly its the in tank pump then. there is only one pump in the tank and its commonly known as a lift Pump. it does draw fuel from both sides of the tank. If weak and failing, then it often cannot provide enough suction to the left hand (Passenger side of the tank.
Ok Lads by all the replies I am taken it that I pull the lift pump out and replace the pump inside the white caseing
