![]() | Home > Technical (L322) > Alternator removal TDV8 |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
Did you have to remove the grille and front bumper to make access easier?
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
No with the rads still in place it would be a bit silly to take them off. Space is tight but the awkward part is getting the Alternator out past the turbo pipe work. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8785 ![]() ![]() ![]() |
Good to know |
Only coolant as obviously all the rad pipework gets in the way but not the header tank that I have read people remove, I really could not see why |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Great write up Mike, gives me the confidence to swap out my alternator. 56 TDV8 Vogue SE
I have realised that nothing in the engine bay of mine is simple to do or get at but with small hands, a large hammer & plenty of expletives any thing can be achieved Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
Put it all back together this morning hardest part was putting the nut on top of the main battery feed on top of the Alternator. Dropped it twice & wasted half an hour with a boroscope & magnet trying to retrieve it. Now charging at 14.6 v & am hoping the battery is ok after being totally flattened, so I may invest in a new one before the frosts start. I would estimate with tea brakes & the odd cigar about 6hrs in total Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
martylennox Member Since: 05 Aug 2013 Location: Co Antrim Posts: 9 ![]() ![]() ![]() |
any ideas on how to get at the alternator wires for disconnection,? im in the middle of the dreadded tdv8 alternator change.
Marty good to hear that now I know who to contact if mine goes being a fellow Antrim man |
small hands required! |
Disconnect the feed from the starter so you can pull it forwards |
Should have added it will come past the turbo pipework just requires a bit of wriggling |
