Home > Technical (L322) > kick down
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
kick down
When I use kick down to accelerate on overtaking it gets to a point and then the engine stutters like it has an limiter on it.
If I increase the speed on the pedal normally I do not get any hesitation.
Does the engine have a limiter? or has anyone else had this happen to them?
Its a diesel engine
Post #217600 19th Oct 2013 8:22pm
At what point do you experience the stutter?
Which diesel do you have?
Mind you the limiter is around 4500rpm on both td6 and tdv8 engines and it wont rev past that point. There is nothing that can't be fixed with a hammer😜😜
Post #217603 19th Oct 2013 8:42pm
srpara
its at high rpm but seems to me that the box should change gear but just seems to hold itself and not change up
It a newish box that was fitted about 20k ago at a LR main dealer
Post #217605 19th Oct 2013 8:52pm
It should kick up to the next gear before you get to the red line even withe your foot planted.
Have you had it long? The gear box may take a little while to adapt to your driving style? There is nothing that can't be fixed with a hammer😜😜
Post #217608 19th Oct 2013 9:10pm
srpara
Only had the car for about a week or so now and was my first time to try out the kick down its not my normal way of driving but nice to know it works just in case I should need it Wink
Post #217610 19th Oct 2013 9:15pm
So long as it shifts smoothly under normal driving conditions there should be little to worry about. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #217613 19th Oct 2013 9:24pm
srpara
ok Thumbs Up no problem at all under normal driving Very Happy
Post #217617 19th Oct 2013 9:41pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Here's a weird thing... You have perfectly described an issue I have.
....but mine is a petrol SC, which has a different gearbox Neutral
If I leave my foot planted it will change up , but takes a few seconds longer than it should.
Never had it looked into as car is fine rest of the time and I don't really want to know Whistle Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #217643 20th Oct 2013 7:56am
