Home > Technical (L322) > Hard into 1st
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Hard into 1st
Hi all,
On my recently aquired RR 4.2 Supercharged I have noticed now and again a thud (ish) change down into 1st gear as the car is stopping.
I have heard it may be a "reset" needed, any ideas.
Otherwise it changes all gears seamlessly and very smoothly.
Thanks
Glynn
Post #217722 20th Oct 2013 4:49pm
JCW
Same on my 07 Supercharged, keen to hear if theres a software update or similar I'm missing Rolling Eyes
Post #217724 20th Oct 2013 4:54pm
Maybe worth a read ….
http://www.fullfatrr.com/forum/topic18940....hange+gear
Or do a search … Thumbs Up ====================================
Post #217726 20th Oct 2013 4:56pm
Had this on my last SC and Land Rover sorted it with software... Thumbs Up
Post #217728 20th Oct 2013 4:58pm
Mine is having this LTB done when it's next in. It sorts out the harsh shifts 1-2-3 and specifically a lift off throttle 3-2-1 shunt.
LTB00267 - Harsh Transmission Shift 1-2 & 2-3 Lift Off Throttle (L.O.T), and 3-2 & 2-1 rollout
It's a software issue and takes 0.2hrs apparently.
In my TDV8 I found the same issue and having the auto box megaflushed made a huge difference to the smoothness of all gear changes. Discovery 4 HSE
Post #217729 20th Oct 2013 5:09pm
TugRR
Mmm . . . interesting.
My AJV8 does this - I thought I'd read somewhere on here this was a characteristic of the ZF 6 speed gearbox ?
So it can be "fixed" ?
Thumbs Up Where do you go after one of these . . . ?
Post #217748 20th Oct 2013 6:15pm
Yes, and the sooner the better IMHO as it will only do damage in the longrun...
Post #217789 20th Oct 2013 11:14pm
n1cktdv8
"megaflush" Shocked
Mine is due in for a service, with it towing for about 30% of it's life is it worth me specifying this type of gearbox flush...the 'box isn't showing any signs of problems but preventing is better than curing ? Is this where I put the car details and a bit about myself ?........
Post #217791 20th Oct 2013 11:23pm
TugRR
^^ Thanks Craig - I'll look into that.
I take it that as it takes 0.2 hrs to complete it is a "laptop" job ?
Post #217842 21st Oct 2013 11:04am
Not sure on 0.2hrs or costs as mine was done as a "favour" by my friendly local MD (who supplies my parts and i convert their customers cars etc)
I will say though, it took a couple of attempts to get it right Rolling Eyes first time made it far worse Exclamation But got their on the second/third attempt... So ask them if you can roadtest it when they have completed their work (to make sure your happy with the results Thumbs Up )
Post #217847 21st Oct 2013 11:17am
TugRR
Post #217850 21st Oct 2013 11:40am
