![]() | Home > Maintenance & Mods (L322) > Gearbox Megaflush |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
What Poll? |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
Craig, you are a clued up guy |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
It didn't appear for some reason... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
sorted Craig, let me know if you want the wording changed.. ... - .- -.
Very helpful... Thank you sir |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Can't megaflush here but would change the filter afterwards.
Eugene, how would you change filter afterwards my friend? The sump needs to be removed to change the filter and then the oil would be lost... Sorry if im being thick |
Of course, you'd be putting another 7 liters of fresh ATF in. To me the flush only helps cleaning deposits out of the system by the flushing action (similar to what happens with hydraulic systems when you commission them).
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Not a megaflush but I've had the gearbox fluid "changed" twice recently on my TD6 and was intending to change the Filter for an original on the next change. Each change involved replacing approx 7L of fluid.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
I am impress someone would actually offer such "service", it is plain stupid. one needs to change the filter and clean/change the magnets and inspect for debris.
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Can I ask a question please?
Can i just check that people who are taking part in the POLL at the top of the page are owners that have had a "Megaflush" NOT OWNERS that have simply had their gearbox serviced...
The filter is built into the sump on your 6 speed FF The "kit" comprises of Sump, new bolts and sump gasket |
the plastic sump, magnets and filter are a one piece unit from Land Rover, you do change the whole thing.
