![]() | Home > Maintenance & Mods (L322) > Couple of Q's on 2006 conversion |
| MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471
In the middle of said conversion at the moment and have a question about the headlamp mounting. The 2006 Xenons I have to fit have the vertical tabs at the top - however the lights from my 2004 that I removed were fixed horizontally with flat tabs on top. How do I fit the new lights? I cant find any pics on this or other RR.net sites to show that bit.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801
according to the how to in the wiki , you need some headlight mounting assemblies,
I have those brackets but they are steel brackets next to the rad and dont appear to have anything to do with fixing the top of the lights.....
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
Just guessing but do you need the new type wing brackets due to light being different shape. These fit to the inner wing and have holes for fixing of light .I had to replace these doing 2010 conversion so its likely these need replaced ? Present :2008 TDV8 HSE
these are a couple of pics of my lights [2008]
oooow that looks exactly what I need - can anyone provide a part number for the top parts? or even a pic from rave so I can get the parts locally?
you could try microcat for the part numbers , links in the wiki. ... - .- -.
Grrrr, trying Microcat and they have loads of blown up drawings but none have the bits I need. "On first name terms with my local Dealer......now."
is it this part you need,ASW760090/80 [new part number is LR011566/65]
i think you need to talk to the man that knows everything about conversions, CAM - TECH - CRAIG...... ... - .- -.
Thanks Stan but no thats not the bit I need - I will PM Craig and may make up a bracket for now.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
I wonder if this plastic mounting piece is available separately? A guy bought a broken headlight off me just to get his hands on this bit......sorry, just seen Paul's post - what he said. |
