Home > Technical (L322) > Possible
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Possible
m.
Post #218522 24th Oct 2013 5:55pm
Glynn
Anybody any thoughts ?
Post #218543 24th Oct 2013 8:36pm
After you clear the adaptations there is a set procedure that Eugene (ebajeema) has listed and must be used to make sure the gearbox learns the correct shift and slip points during use. I'd print it off and go back and ge the adaptations reset and then do this procedure to get the box in decent nick.
After that its a flussh and filter change on the box and after that a strip down Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #218622 25th Oct 2013 9:24am
ebajema
http://www.fullfatrr.com/forum/topic17348-75.html
Have a look at page 6, right in the middle is the adaptive drive cycle. After you have done that, it is still not perfect, that takes a few weeks. Mine is now silky smooth again, the way it should be. MY 2010 5.0 SC Galway green and sand interior!!
Post #218623 25th Oct 2013 9:27am
