![]() | Home > Technical (L322) > The Diesel Fuel System Cleaner Thread.... |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Just to recap from the winter tyre thread.
My take - Craig recommended diesel cleaner and he is in a position to know. I've been meaning to get some but haven't got round to it yet. Haven't used the car that much since though.
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
I got some BG244 and used it, I think it has improved things as I can't remember why I bought it in the first place as engine runs smooth. If it was always this smooth I wouldn't have bought the cleaner in the first place - if that makes |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Its good stuff |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
What is it? Where can I get some? |
AMAZON |
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Redex sorted out a stutter on idle in my wife's BMW 320d |
Why didn't you follow the instructions? |
The less fuel in the tank, the neater/stronger the mix... The more chance of clearing a partial blockage rather than just gently cleaning the fuel system as with mixing in a full tank of derv |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
I put a can in to try and clear up a possible EGR issue. Seems to have made a difference, wether placebo or not. Got - 2017 SDV8 Autobiography in Loire Blue
| Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174
This chap, Mark, supplies it and also supplies a top up at the pump additive, Archoil.
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
I use the Redex Diesel Additive fairly regularly with the FFRR, normally get a large bottle from Halfrauds for £12.99 and put 1/4 bottle in per tankful. I find it does smooth things out a bit...especially as I fill up at Morrisons. I go through a full tank of diesel per week, getting 625 miles per tankful and it makes cold weather starting easier.
Well, I bought a couple of bottles of these, the only diesel injector cleaner I could find in Switzerland, and added to a full tank of fuel. Each is meant to treat 60 litres, so slightly overdosed.
Well I bought some Archoil AR6400-D and it clearly says on the instructions not to overdose!
| All times are GMT |
