Home > Technical (L322) > Warm start |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I've just had that problem with my D1 V8. It needed the fuel pump (which you did) AND the fuel regulator. Now the FFRR engines are a few decades more advanced, so I don't whether that's relevant on the newer ones. |
26th Oct 2013 2:06am |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 |
Cheers, got the filter/regulator coming tomorrow. It's an easy fit so will do it myself and let you know. Owning a Range Rover is the land based version of a boat...a hole in the road in which to throw regular bundles of money! |
27th Oct 2013 9:04am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
i had the same issue with warm starting for almost 3 years i sorted it by changing the pump and the filter/regulator now starts perfectly
27th Oct 2013 11:35am |
