Home > Technical (L322) > tdv8 cylinder location/fault P021a
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
The FF has developed a constant missfire & when I plugged it in today came up with Injector seven injection timing.Obviously before I take this any further I need to identify the cylinder & possible causes. I think if my interpretation of the workshop manual is correct its somewhere in the engine!!!!! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219130 27th Oct 2013 8:11pm
from rave its a bit arseards way round but says:
*note:when viewed from the rear of the cylinder block
RH bank: Front cylinder number 1 through to cylinder number 4
LH bank: Front cylinder number 5 through to cylinder number 8
so i recokon second in on LHS when looking into the engine bay. Thumbs Up
NO SCRATCH THAT.......
RHS 3RD IN AS LOOKING INTO THE ENGINE BAY. Thumbs Up Thumbs Up
combine the text description with the cyl layout and you can figure it out!
cyls are
4 8
3 7
2 6
1 5
so looking from the rear would be looking from "behind" cyls 4 and 8 otherwise the handing doesn't make sense.
so 1 and 5 are at the front of the car and 4 and 8 are at the back of the engine bay.
 There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 27th Oct 2013 9:08pm. Edited 1 time in total
Post #219142 27th Oct 2013 8:52pm
So you think driverside two cylinders back from the rad ? its been a long day & this seems to be a tad confusing lol Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219147 27th Oct 2013 9:04pm
^^^edit.
see edited post, you are right its Censored confusing. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #219149 27th Oct 2013 9:10pm
got you,thats where i had it but seemed to be going around in circles Very Happy then i decided I was loosing the plot. Interestingly I had a o ring fail on the leakoff pipe on that cylinder leaking diesel every where three weeks or so ago so wonder if that maybe related? Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219152 27th Oct 2013 9:17pm
Thumbs Up Would be surprised if it wasnt part of the same issue.
Swap a couple of the injectors around and see if the fault moves Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #219153 27th Oct 2013 9:22pm
At least they are not programmed like on some ford engines, wonder if that one had a high leak off. thanks for helping to save my sanity lol Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #219155 27th Oct 2013 9:28pm
