![]() | Home > Technical (L322) > Any ideas! |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
It's the HEATER ACTUATOR DEFROSTER FLAP VENT.
| paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502
Ah ha!! Thank you sir. I googled the numbers on the side to see if anything came up but no.
I had no heat to my feet but I don't know if it was that which was broken. Garage fixed it.
Cheers Kurt , Evidently the googling on a cold, dark garage floor at half one in the morning isn't the best idea for yielding positive results!! |
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
See my post ' weird noises from behind dash' there are four of these stepper motors in the heater, £16 each delivered, off the bay. At least this one is easy to access by the look of things. You must order the correct one: they look the same, but each motor contains a code that identifies it's position in the heater to the ATC ECU. |
Cheers mate. I'll get on it!
This is the one. eBay Item No. 350847743462 nice people to deal with too, ordered at 2pm Friday, received 9am Saturday |
| All times are GMT |
