![]() | Home > Technical (L322) > My rear washer doesn't work |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
there are 3 entries in the wiki re this Jammer |
| Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212
Cheers Stan, I've seen those but as far as I can see there's nothing on the whereabouts of the pump? I'm getting nothing through my hose so the problem is before the problematic area others have spoke of |
isnt the pump at the front somewhere?
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Did you take the pipe off before the NRV? They are bad for blocking/failing.. Previously..
Pumps and tank are in front of your NSF wheel, behind the front bumper... Access is found behind the splash guard |
Cheers Craig I'll take a look tomo! Duno what NRV is? |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Non return valve - often gets stuck resulting in lack of flow. |
Ahh ya beat me to it |
Where would that be at the wiper end? |
nrv at the wiper end.. ... - .- -.
It's the plastic bit in the pipe, just before it goes into the rear wiper assy.... Take the pipe off before the NRV and try the skoosher!! Previously..
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
My rear wiper wasn't working but all sorted now Click |
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
. . . Before you do any serious dismantling, check the parts mentioned above.
| All times are GMT |
