Home > In Car Electronics (L322) > Dead Battery
markdotreed
Dead Battery
Going to Change the battery tonight on the SC as it's on it's way out. I've read in one place to disconnect the negative and leave for 15 mins before removing the positive??? But in other places, including powerfulUK Utube it doesn't say that?
Any opinions??
TIA
M Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #219750 30th Oct 2013 4:49pm
i take off the positive and then the negative without waiting in between , but thats after the range has been quiet for about 20 minutes... ... - .- -.
Post #219757 30th Oct 2013 5:01pm
markdotreed
It hasn't moved all day and I'll do it as soon as I get in so should be OK then..... Ta Regards
Mark
Post #219761 30th Oct 2013 5:07pm
when you unlock it , lift the bonnet and leave for about 20 mins and that will allow all the ecu's time to power down . ... - .- -.
Post #219764 30th Oct 2013 5:11pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I always follow the process in the wiki - don't fancy the pyro charge on the positive lead going off. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black β€”β€”β€” Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #219797 30th Oct 2013 7:30pm
I just disconnect mine. Never had any problems and my pyro charge is still intact Laughing Laughing
Post #219802 30th Oct 2013 7:42pm
Says on the slam panel to wait 2 mins.......
Personally i unlock it
Open the bonnet
Wait 10 mins
Disconect
Never had an issue so far Thumbs Up
Have disconnected a ff quicker (not mine) with no issues but wasnt mine and didnt have time to pratt about. There is nothing that can't be fixed with a hammer😜😜
Post #219843 30th Oct 2013 9:42pm
markdotreed
Changed the battery yesterday. The only 'awkward' point is that there is what looks like a fan in front of the battery that you have to remove in order to get it out. It's only plastic but it was awkward getting to the fixings and you have to tape the nut to the socket to reinstall as you can't get a hand anywhere near the threaded section. So, all in all it took a little longer but a good job done. Regards
Mark
Post #220455 3rd Nov 2013 11:13am
What is this?
Post #220457 3rd Nov 2013 11:23am
A big fuse David...
Post #220459 3rd Nov 2013 11:36am
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
In the handbook it goes on about this but mine does not have it. After a bit of research I discovered that Ford stopped fitting them when they bought RR. However did not see fit to change the books!! Did leave me a bit confused looking for the + jump point after my Alternator failed a few weeks ago. Very Happy Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #220462 3rd Nov 2013 12:08pm
